I needed to have the Dex Cool changed in my 02 Z06 this year and after researching the method, I found that it was easier, better, and inexpensive to have the dealer do it with their BG flush machine. They pour a cleaner in the reservoir tank, let it mix, then hook up the machine to the hoses. While the engine is off, the old coolant is flushed out and rinsed, then new coolant is added without the dealer doing any hose changes - it's all automatically controlled, the tech just watches the procedure. The coolant is disposed properly, the corvette is set for the next five years, and I got to watch. Cost me $105 and it was worth it. Took less than 25 minutes and I was on my way. I do recommend the method if your dealer charges a reasonable price. I checked with another dealer and was told that it would be $150. Dealer prices are not the same across the board. Of course, if you like to change the coolant yourself, use Hib's directions. Just don't pour the coolant onto the ground as a disposal method nor dump into a sewer.
Barrett
Actually, the dealer is fairly close to you, Bozarth in Lone Tree (470 and I25). Ask for Greg Ruybal (direct line 303-858-2438) and tell him I referred you. You could request the World Class Tech, Noel, to do the work for you.
Barrett Benson
