Okay lets try again,,90 c68 a/c. will set a/c at any temp,say 65.will jump to 75 ,and blow hot air. have changed out the dash head unit know good. Changed out the vacuum control module .same thing .Changed all vacuum lines ...they needed it.also changed the check valve at the rear of motor. Also cleaned as many grounds as the factory manule shows....has n`t anyboby had something similar? thanks Bill
