Whiplash
Hi everyone. This is my first post on the forum. I just bought an one owner 71 Convertible, 4spd, AC, 350, SSG project car. The body is in great shape and it runs great.
I'm doing the required maintenance, new front suspension, steering, oilpan gaskets, rear main seal, radiator, etc.
When I pulled the oil pan I found a thimble full of hard plastic pieces, yellow/brown in color. They definitely have some kind of structure and are hard not pliable plastic. When I pulled the oil pump I found a ton of plastic in the pickup screen. Probably about a quarter cup of the pieces. There was nothing in the oil filter (I cut it open to check).
Anyone have any idea what this would be? If it was one piece when it went into the engine there is no way it could have made it through the oil passages from the heads down so I don't think it was dropped in from the valve covers.
The engine runs solid, starts right up, no knock, good oil pressure. I expect the oil pressure to be even better now that it has a clean oil pump and pick up installed.
I'm at a loss here. A friend of mine said it might have been some type of plastic plug(s) knocked out of the block at the factory when they put the motor together. I just don't have a clue.
I have pictures of the pieces but I don't know how to insert here on this forum.
Any ideas would be great.
Thanks,
Whiplash
Thanks,
Whiplash
