Anyone have experience with Swain Coatings??
WhalePirot
SoCA
1984 White Z-51/ZF6-40/Shinoda body
From their web site: http://swaintech.com/sindex.html
The theory of insulating the exhaust system to retain heat is commonly overlooked by most racers. After heat has performed its function in the combustion chamber, it travels out the exhaust port to the header. If the Gases are allowed to cool, they lose velocity and the scavenging effect is reduced. If by insulating the exhaust system, gases inside are kept at the highest possible temperature, the resulting effect is a greater exhaust gas velocity and higher efficiency. Each gas pulse moves through the pipe faster, making room for the next and pulling it along. This reduces back pressure and increases the "super-charging" effect created by the now of high velocity gases.
Insulated headers also reduce radiant heat and lower underhood and cockpit temperature. By reducing air intake temperature 10°F, a horsepower increase of 1% results, a 30°F drop equates to a 3% horsepower increase. This is inexpensive horsepower.
Swain Tech engineers have developed several heat management products for use on headers and exhaust systems.
White Lightning Coating
Swain Tech Thermal Barrier Coating, TBC-EX -- TBC-EX is a 3-layer .015-.020" thick permanent coating. The coating is pearl white in color and extremely durable. It reduces radient heat by more than 50%. (It is NOT Hi-Temp paint like other products.)
i've witnessed an improvement in header efficiency, felt in my seat, after wrapping my old headers. I also know Boyle's Law, so the science makes sense.
How does this firm's products work in the real world?
TIA for the poop.
:w
what is their web url?
It sounds like it should work, but I am not sure how much it will help... is the product do it yourself, or do they do it for you?
