- Moderator
- #1
vetteboy86
I am thinking about a rear end swap on the vert. Now I have a Dana 36 with low gears. Was thinking about purchasing a whole rear end unit with a Dana 44. Has anyone done it before?
vetteboy86 said:Just want to be ready for anything. I spin them so bad out of the hole, I am going to put bigger, wider, stickier tires on and eventually I think something will give and from what everyone says the D36 is the weekest link.
Yes it has been done many times. If you plan on putting on drag slicks put the 44 in first that way you can sell the 36. If you race it with the 36 all you will have to sell is a hunk of junk unless you have an engine that is weaker then that weak sister rear-end :ughvetteboy86 said:I am thinking about a rear end swap on the vert. Now I have a Dana 36 with low gears. Was thinking about purchasing a whole rear end unit with a Dana 44. Has anyone done it before?
