S
Sams '66
It is on the floor pan drivers side....just a angled plate with a hole????
Ideas? John Z?
My AIM is wrapped under the tree....:s
Ideas? John Z?
Sams '66 said:Those are the outers....
I see where they (inner shields) attach to the frame and to the bracket.......how is the braket attached to the floor pan? the drivers side is bolted.......should the passenger side be bolted also?.......there are no apparent holes.
thanks?
youwish2bme said:Ron just to help man. The inner shield goes from that bracket forward inboard of the frame. The other shield is outboard of the frame and connects to the inner fender well and the fiberglass just below the vents.... Sam if you can get the dimensions of those inner shields it might be cheaper to cut them out yourself than paying the 30 bucks a piece for em... Dave..
