Anyone need any lt5 engine parts?
  • Thread starter Thread starter MrCrowley
M
MrCrowley
I have a complete running engine that I will be disassembling and parting out. I will be keeping the block, but everything else must go. The engine is a prototype 4bolt block with the 91 style plenum, and injector housings. It is complete from the throttle body down to the oil pan. Let me know what items you might need.
Looks like you've more than a few LT5's lying around - do you do a lot of work on ZR-1s?
:s
Well that is the motor I will be parting out, but that is the only picture I have of it. That picture was taken at SGC. And yes I do work on zr1's. I will be in the progress of building that block(4bolt) to a stroker. The cid is still unknown on what I will go with, but it will be big!
The items that have been sold so far are;
plug wire set
throttle body and air horn
complete head set
Here is what is still available;
injectors, and rails
water pump
alternator
starter
bottom end rotating assembly
a/c
plenum, and injecter housings, water pipes
coils, and probably some other items I am forgetting
I am interested in the plenum and injector housings, could you drop me an e-mail with details of prices?
Thanks.
Can you also email me on a price for the Plenum and injector housing.Do you have any exhaust manifolds?cam covers?...Let me know thanks JERRY
