corvette66
I need to know where the starter wires hook up too (on the starter). There is a big black wire directly from the battery, it hooks up to the largest bolt on the starter selnoid. but there are 2 other little terminals sticking out of the selnoid on the starter, and there are 2 more wires. Do one of each of thoes wires go to the 2 small terminals, or does the red wire also hook up to the big black one? So in otherwords, is the terminal (closest to the motor) just open? no wires hooked to it?
Also if you can check the distributor for a wire. If you look at the ignition coil ontop of the cap, there is 3 plugs that go in the coil. One is a big connector with about 4 wires, the other is a white connector, with only one wire, and the last one should be a brown connector. OK... on the brown plug, if you disconnect it and pull in out, is there a real long (aprox 6") yellow wire connected to it with a big cylindrical capacitor looking thing on it. Or is it a real short wire with nothing on it? I think the cylindrical thing has a mount wraped around it, and it maybe bolted right behind the distributor thing.
thank you
thank you
