Are breaks "do it your self"
S
Silver97
I have a 97 coupe and I will need breaks really soon. I know nothing about replacing the pads but my older brother says he can do them for me? Should I let him or should I go to the dealer for the break job?
Suggestions?
K
Karl Snedeger
It is not hard. All you really need is the right tools. As long as your rotors are still good all you have to do is pull the calipers off and install the new pads. Remember to grease the pins that attach the calipers. Be careful and watch the fluid level when you press the pistons back into the calipers as this will sometimes overflow into the engine compartment. Also remember to use Loctite on the bolts that secure the calipers to the pins and on the mounting brackets.
D
DkBG
I would have the rotors turned at least a minimum amount . Cliff
Fenton, Mich
'02 Torch Red Roadster w/lt oak and a C5-R 427
Don't forget to use a torque wrench on the lug nuts so you don't over-torque them and warp the rotor. I believe the torque # is in the manual.
One of the tips I learned in this forum :D
Brett
Spiderman
Grand Haven, MI, USA
Gorgeous White '91 Coupe
Over the years I have discovered that "breaks" are always easy.:D On the other hand, "brakes" aren't that difficult either.
I'm getting ready to do mine myself. Wish us luck.:)
Spiderman :w
S
Silver97
Thanks for the tips,
Spiderman, I am not to good at english, it is my second language but thanks for the feedback.
I have decided to let my brother fix them for me :)
Thank you
J
John L
Don't forget to take a break every now and then while your're fixing your brakes!
