Stewballs
I am a new member. I can't keep this short... sys light started flashing, about a year ago. Read forum. Checked every connection I could find... and charging system. All good. Install used DIC. Fixed sys light flashing, and fuel and gauge buttons not responding correctly. Next asr light, security light and again... sys flash together. Read forum. ECM is being repaired at SIA. Before ECM removal, engine would cut out at hi way speed, like a long engine miss. This quickly turned into engine dies. ICM is external, I poured cold water on it, engine ran perfect. Til it got hot again. I put a bag of ice over it, with a small hole in it, over the module / coil location. I used 3 bags!! But made it 65 miles! When it began missing the ice had melted. I bought new module and new coil. I made it about 60 miles engine miss/ engine dies returned. However water and ice did not remedy it this time!!! Towed AAA 65 miles. This was... my daily driver. Any suggestions or links would be appreciated. Thanks
