assembly lubes
grumpyvette
Loxahatchee, FL, Palm Beach co
these I can recommend these products with zero reservations, the white and red stuff others sell are in my experiance not as good
assembly lube (put on cam and lifters and bearings and rockers)
http://store.summitracing.com/partdetail.asp?autofilter=1&part=CRN-99004-1&N=700+115&autoview=sku
cam break-in concentrate (yes its BETTER than EOS)
http://store.summitracing.com/egnse...e&Ntk=KeywordSearch&DDS=1&N=700+115&x=35&y=13
heres good stuff to spray on rocker arms just before firring it up the first time
http://www.atlantaimported.com/proddetail.asp?prod=221-415
BTW ive seen guys use STP oil additive as a replacement, thats a VERY BAD IDEA, STP has almost no ZINC or MOLY in it! its nearly worthless in that application
most guys don,t think to spray the valve springs and rocker arms and pour oil over them just prior engine start-up and both get hot fast if not soaked down before starting the engine, and don,t forget a couple magnets, youll be amazed at the crud and metalic dust they catch
and prevent from reaching the bearings and lifters
http://www.kjmagnetics.com/proddetail.asp?prod=SMCO-62
