S
Stingray72
Last month, I installed MSD's pro-billet distributor with the tach drive and vacuum advance, described in my first thread on this board a while back. Everthing went great and the car runs fantastic, but the tachometer didn't work when I hooked it up. The distributor was shipped with the tach drive facing the opposite direction of the vacuum advance. After looking at the old distributor, I reasoned that it was simply driving the tachometer in reverse, and that I just needed to flip the drive gear around so it's facing in about the same direction as the vacuum advance. But when I did that, the vacuum advance was in the way and it was impossible to connect the tach drive cable!! I can't believe this. I suppose MSD never did any test-fitting.
Anyway, for any of you that own this distributor, how did you get the tachometer to work? Does driving the cable in reverse hurt the tach? Which way does the drive gear have to face? Is there a more compact vacuum advance canister available that will clear the tach cable? Do I have to get the adapter that MSD sells to reverse the drive direction? I really hoped to avoid the adater because the area around the distributor is so compact.
Thanks a lot!
Thanks a lot!
