Auto Tap info for P0132.
  • Thread starter Thread starter UB2 SLOW
U
UB2 SLOW
One of the three codes I keep getting is P0132. The other two are P0152 and P0300. I have a new opti and wires coming for the P0300. Here is the freeze fram info for P0132. Any suggestions?
P0132
AutoTap Diagnostic - Version 3.00
Date: 5/20/2006 9:42:24 AM
Hardware Serial:
Check Engine Light: ON
Time Since Codes Cleared: ---
Distance Since Codes Cleared: ---
Drive Cycles Since Codes Cleared: ---
Confirmed Diagnostic Trouble Codes:
Code: Description:
P0132 HO2S Circuit High Voltage Bank 1 Sensor 1
P0152 HO2S Circuit High Voltage Bank 2 Sensor 1
Possible Diagnostic Trouble Codes:
Code: Description:
--------: EMISSION TEST STATUS :--------
Emission Status: <SELECT DATE>
Vehicle Model Year: <SELECT>
OBD Compliant: Yes
Misfire Monitoring: Complete
Heated Catalyst Monitoring: Not Supported
Comprehensive Component Monitoring: Complete
Catalyst Monitoring: Complete
Fuel System Monitoring: Complete
Evaporative System Monitoring: Not Supported
Secondary Air System Monitoring: Complete
EGR System Monitoring: Complete
Oxygen Sensor Monitoring: Not Complete
Oxygen Sensor Heater Monitoring: Not Complete
A/C System Refrigerant Monitoring: Not Supported
--------: FREEZE FRAME DATA :--------
Generated by DTC code: P0132
Fuel System Status Bank 1: CL-1
Calculated Engine Load: 7.1 %
Engine Coolant Temperature: 180 °F
Short Term Fuel Trim Bank 1: 0 %
Long Term Fuel Trim Bank 1: -1.6 %
Short Term Fuel Trim Bank 2: 0 %
Long Term Fuel Trim Bank 2: -1.6 %
Manifold Absolute Pressure (MAP): 10.6 in Hg
Engine Speed: 1739 RPM
Vehicle Speed: 50 MPH
Mass Air Flow Rate: 2.363 lb/min
Throttle Position Angle: 0 %
