Please post how you make out, I'm interested in the lower Temp fan switch if it does if fact turn the fan on at 211* F. Let me know. Thanks.Ken, Thanks. I'll pick one up and measure the closing temp before installing.
I tried to order the TFS4 switch from AA and they told me then have non in stock and non in their warehouse?? WTF! So I cannot even order the switch thru them??
Mid America Motorworks does sell a switch that closes at 200* F and opens at 185* F for $14.99 part# 609-106 That may be a little to much cooling but I might give it a try.
Try your chevy dealer. Tell them you need it for an 89 camaro 350 CI. Check the temps for open and close. I'll see if I can cross ref.
The AC delco # you cross referenced too (#D1855B) comes up as a part for a '90-'91 Camaro with 305 cu inch motor VIN E
It also cross references to a '92 Camaro RS with the same motor.
Various Caprices '86-'92 with the same 305 motor.
And '92-'93 Celebrities with 2.8L V6 motors VIN X
Are you sure this is the right part??
OK after further reveiw......
The local Advance Auto counter retards, all of them, including the manager told me we can't order a BWD TSF4 coolant temperature switch for you because we don't stock it...... the warehouse doesn't have any...... we don't know how to place a special order when the warehouse shows no stock.... WTF!!!!!!
So thanks to Ken, YES!!! The AC Delco part # D1855B witch crosses to a GM part #14043275 can be ordered thru any Chevy dealer. It is a low Temp grounding switch turning the fan on at ~ 215* F and off at 200* F
Not to be confused with the OEM switch AC Delco part# D1852B witch crosses to a GM part #14043276. This is the OEM Temp grounding switch that turns the fan on ~ 238* F
For those of you looking for more cooling MAM (Mid America Autoworks) does sell an even lower Temp switch witch will turn on at at 200* F and off at 185* F, part #609-106 $14.99
