B0516H code
  • Thread starter Thread starter Wolfmanjohn
W
Wolfmanjohn
Greetings, all,
I was getting ready to do a little intake mod on my '04 A4 coupe and thought, on GP, I would check the DIC for codes beforehand. All was clear with the exception of group 60 - IPC, which showed a B0516H code. When I looked it up in the Helm factory manual, it read, "vehicle speed over 200 mph for 1 second/PCM unable to process correct vehicle speed from VSS/intermittent or erratic VSS operation".
Say what?! I know I didn't drive that fast, and in 10 months and 5000 miles, I've only chirped the rear wheels once! Any ideas as to where this code might have come from? Is this a fairly common code? Is this some kind of BS code?
I just find that code's presence very interesting, hence the curiosity. Thanks in advance for any information you all might have.
Did you reset it? If so, take it out and see if you can set it again.:Steer ;)
J/K, that's the first time I've heard of that code. I didn't think a stock C5 could go that fast.
