- Joined
- Oct 7, 2007
- Messages
- 720
- Location
- Amherst, NY
- Corvette
- 1996 Torch Red Coupe (Prior 1988 and 1989)
I think you are down to two issues. EGR not opening properly and carbon buildup in the heads messing up combustion. If we focus in on the EGR, you validated that the EGR ports are open and that the ECM is sending the signals causing the EGR vacuum feed to work when driving off idle. You tested your EGR and confirmed it does not open properly at lower vacuum pressures. My new EGR (reference point) starts to open at 2-3 Hg-In, while your EGR reguired 10 Hg-In. If the EGR vacuum feed is only sending 3-10 Hg-In off idle, I'm not sure how your EGR can properly operate (this EGR is not an on/off switch but has variable openings based on load). When I installed my new EGR, I ran a few tests to see how much impact it actually made on pinging. Bottomline, my L98 will ping regardless of gasoline octane used if the EGR is not fully functional.
