Back-up lights
  • Thread starter Thread starter 76L82
7
76L82
One of my back-up (reverse) lights...the left hand side, on my 76 stays on when all the lights are turned on....even when I am going forward.
I have looked through my manuals but I haven't come up with where or what controls the back-up lights. I am assuming there is a switch off the transmission somewhere..my car is a 4 speed...similar to that on an automatic transmission, that switches the lights on when in reverse. (The other dilemma is why the right hand side back-up light doesn't come on as well..go figure?)
However, I haven't had a chance to crawl under the old Vette to take a look...was holding out to hear that the control was in the console panel....wouldn't that be too lucky to hope for!! :beer :beer
Correct.
As far as only one light doing it, the other probably has a bad bulb or connection, since they should be fed off the same wire. I can't be certain about your '76, but the wire on my '79 goes to one of the lights, then slices off the socket to go to the other. I don't know which is which, though. So, if it goes to the left first, and your right-side bulb and socket check out, you might have a bad wire between the two.
Joe
There's an (adjustable) switch on a bracket bolted under two of the trans side cover bolts; it has a rod that attaches to a hole in the reverse lever on the shifter. The backup light circuit is independent of any lighting circuits - should only come on when the switch is closed, whether the lights are on or not.
Thanks guys! - Looks like I may have to get a little dirty this weekend crawling around the Vette...
