The ways of Bubba are mysterious and befuddling...Why would someone plug the hose for the timed spark vacuum that connects from the distributor to the carb with a ball bearing? Never noticed it until now.
Mac
Thank you for the input, guys! I hope I didn't offend anyone with my remarks re: Bubba.
I've never used a ball bearing for a plug, nor have I left the vacuum advance blocked for anything other than troubleshooting. Mind you, I've never turned a Vette for drag racing...
Mac
What the guys said above was disconnecting the vacuum canister and plugging the line going to the carb to prevent a leak. The OP found the line still attached to the vacuum but plugged- which accomplishes nothing.
That's Bubba in anybody's book. otfl
Your picture shows it being done backwards, usually the BB is placed at the end of the circuit for easy removal if needed and not the source, in this case at the vacuum can. The desired result will work either way, it's just easier if done at the circuit being bypassed.
It is usually done to hide something such as a visual emission test, potential buyer, judging, etc.
Good question. Does the vacuum can leak?
Mac
Car fully brought to operating temp, under light to moderate steady load and will stumble/detonate right before throttle is increased sharply, then will get going.
Is that stumble AND detonate? Too much vacuum advance at steady cruise speeds can cause surging or detonation at throttle tip in. It would be unusual if you're seeing either/both with the vacuum advance already inhibited (?)
Uhm, will try that tomorrow when the weather clears up. Is this with car runiing or off?You can check your vacuum can by applying vacuum to it and pinching off the rubber line. It should stay activated until you release the vacuum and then snap back. If you have a hand vacuum pump use that or put the hose on it an suck on it (if you have good lungs).
Tom
