Ballast resistor
00fxd
B.C. Canada
'65 Convertable
My ballast resistor seeems to have almost no resistance, so I checked and it has 12v at both sides with the key on. I'm expecting it to show about 7v on the neg side. What resistance should it show?
At room temperature, with the wires at both ends disconnected (so you're only measuring the resistor itself), it should show between 1.0 and 2.5 ohms; you'll need a digital VOM to measure it accurately. Original specs were 0.6 ohm prior to '65 and 1.6-1.8 ohms from '65 on, but there's a lot of variabiilty, especially with the reproductions.
Thanks again John. Yes it does show a resistance of 1.9 ohms. How should that affect the voltage to the coil? I thought the coil got a full 12 volts on the 'start' circuit, then the voltage was resisted down to 7ish volts through the resistor on the 'run' circuit to maximize point life.
Yes, that's correct - the coil gets a full 12 volts when cranking through the wire from the "R" terminal on the starter solenoid, and gets resistor-reduced voltage through the other wire when you're in the "run" position. You have to measure the resistor-reduced voltage at the coil (+) terminal, so there's a load applied to the resistor; a VOM doesn't provide the same load.:beer
So with 12v to the resistor, I'm measuring 12v on the coil side as well. There is no back feeding from any other source.
John, I've been meaning to mention, in a previous thread, some time ago, you mentioned that using a small block front sway bar with a bb rear sway bar would result in oversteer. Your dead on! I'm now on the hunt for a larger dia front sway bar. It was quite a suprise to me, considering the wimpy dia of the rear sway bar.
The Corvette engineers spent a lot of time and effort balancing the chassis setup for close-to-neutral handling, with terminal understeer for safety in limit-handling situations. It doesn't take much to "un-balance" that production setup, and adding a rear stabilizer bar to a car that didn't have one originally is guaranteed to upset the chassis balance (due to increased rear roll stiffness) so limit oversteer becomes a problem. Most people don't understand chassis tuning and the drastic effects minor changes can make, especially when they're only made at one end of the car; it's pretty tough to "out-engineer" the engineers when it comes to suspension development.
The aftermarket outfits that sell sway bars do their customers a great disservice by not explaining that you can't fiddle with the setup at just one end of the car without generating undesirable limit-handling results.
I noticed the same oversteer problem when I tried a larger aftermarket rear bar on my BB 67. after a year I pulled it and put the stock bar back on. car now handles better with just that itty bitty bar.
How about increasing the diameter of the front (anti)sway bar when adding a rear where none existed before? This should be OK, no? :naughty:
Yes, that's a necessity in order to maintain the chassis balance; the factory BB rear bar was always paired with a 7/8" front bar (SB was 3/4") or 15/16" with F41 springs.
