M
Monkeywrench
Well I've been doing a lot of reading thanks to your guys suggestions of the best books on BB buildups and I'm almost ready to head off ot the machine shop (almost being a very relative term)
So does anyone have some ballpark ideas of what machine shop should charge so I can judge who is giving me a good deal.
What I need done:
I have a block that has supposedly been hot tanked and bored 0.030 over. It has a small amount of surface rust on it so it needs to be checked (for bore size and deck flatness) and needs to be cleaned up again.
I was also going to have them install the cam bearings and freeze plugs.
I do not yet have pistons or rings. Are they going to need them before they check /rebore to check the clearances?
I have a crank that has been stamped 0.010 so I assumed it's been turned too. Would I best off giving them the crank and have them assemble the crank and bearings into the block to check clearances? I have heard align boring is overkill for a street BB.
I have a set of open 118cc chamber, 256/114cc ports heads that already have the valves and springs installed. On the bottom they have a tin bit of scale and surface rust. Can they be cleaned with the values in or do I need to remove them?
After I get back a block with a crank installed I think I can take it from there.
So what do you guys think a ballpark price would be for each step?
Thanks for the info. I'll definitely be back with more questions.
What I need done:
