alden
Hi, I recently purchased a 1968 Corvette Coupe with a 327/350 hp 4-speed. I was told that the car needed a new battery. I found that the battery would take a full charge and readily start the car. After sitting for about a week I found the battery completely dead. I pulled the battery and charged it. Upon connecting the negative cable, a very slight spark jumped to the terminal. I closed both doors and again a spark. I disconnected the leads to the alternator, again a spark. I tried the key, a spark when shut off. I pulled the fuses, again a spark. I disconnected the leads to the coil, again a spark. I did not go near the starter/solenoid. I have concluded that the battery is fine but there is definitely a current drain. I have no idea where the current is flowing. Any suggestions? Thank you.
Alden
Alden
