battery issue
642buteo
Brampton Ontario
1999 silver vette ,78 silver ann
sorry if this has been covered before (searched posts and received some answers). However I want to change delco pro battery in my 99 vette,Car had a prior battery leak 8 years ago ,which prior owner disclosed to me. What is procedure to change this current delco battery as precaution . I have ordered a Optima red top Will my radio lock out when battery is disconnected,I dont know code. Will radio lock out right away,Can I get a plugin interim supply while i change battery.Will other issues relearn when I drive. Basically if anyone could provide a quick walkthrough it would be great.
You disconnect the battery cables, remove the battery, put in the new battery and reconnect the cables.
Think twice about the Optima, however. While it is a "gel cell" and, thus, less likely to "leak", in recent years, in my opinion, the owners of the Optima brand (Johnson Controls), trying to reduce the retail price and gain shelf space with mass marketers, has reduced the quality of the product. In my opinion, today's "Red Tops" don't have the reliability/durability the original Optima design once had. The most recent one I used lasted only 18 months. Admittedly, I subjected it to two deep cycles, but I feel a good battery for Corvettes needs to be somewhat tolerant of deep cycles at least to the point of being able to withstand more than two.
Problem is, with car batteries, like many other products, there are no free lunches. Batteries that are highly-reliable, truly long-lasting and leak-free costmore than Optimas.
The best battery on the market for Covettes, IMO, is the Odyssey. Unfortunately, they're not cheap, but they do have a projected life of 7 years, are more tolerant of deep cycles, are capible far higher cranking-pulse output than most other batteries.
There is more information on the Odyssey battery right here on the CAC at:
Extreme Battery - Corvette Product Reviews
thank you for the feedback. I was worried that once I disconnected battery I would have secondary issues with radio etc.Sounds like something I can do. I have already committed to buying battery ,hopefully it will be good move.
Sorry Hib, but Optima's are not gel cell, but spiral wound lead acid battery's. Without seeing the bad Optima battery's and testing them, my guess would be that they were sold to customers long after they were made and that they sulfated internally before they were sold. That is why it is important to check the build date stamped on the battery AND have it load tested properly (carbon pile tester) before buying one. Odyssey's are indeed quality battery's, but again check the build date and have it tested properly before purchasing.
Hi
I saw a post about reseting your radio code. Do a search "radio code reset" you will find a few solutions to your problem.
