Tonymarine
Hello
To say my car is in trouble is an understatement. It’s been to 2 different mechanics with no solutions.
It appears to have to have many electrical issues. While driving the vehicle, the instrument panel will light up with “reduced engine power” gauges will go to zero, fuel, gas etc. Radio cuts off, AC stops working (still blows air, just not cold).
Once you turn the car off and turn it back on everything works again. Sometimes for 5 minutes, sometimes for an hour. I have reset the codes and they all come back.
Right now there are 58 codes that show up, most of them deal with a lack of communication.
Now to make things better the battery dies if it’s not disconnected when you stop driving the car for any length of time. Obviously there is some kind of drain on the battery. I did notice that the air conditioning button, which controls the fan speed, has a light behind it that does not go out regardless of whether the AC is on or not. I am assuming this is what is draining the battery.
Here are the codes:
1. 10 - PCM (Powertrain Control Module)
(P1626H) Theft Deterrent Fuel Enable Signal Lost
2. 28 - TCS (Traction Control System)
(U1301H) Class 2 Short to Battery
(C1226H) Wheel Speed Sensor Circuit
(C1293H) Master Cylinder Pressure Sensor Circuit
(U1000H) U1000 and U1255 Class 2 Communication Malfunction
3. 40 - BCM (Body Control Module)
(U1255H) ECU Malfunction
(U1096H) U1000 and U1255 Class 2 Communication Malfunction
(U1016H) U1000 and U1255 Class 2 Communication Malfunction
(U1255H) U1000 and U1255 Class 2 Communication Malfunction
(B2527) Horn Relay Circuit
(B2593) Column Lock/Unlock Drive B
(B2721) PASS-Key Detection Circuit
(B2723) PASS-Key Detection Circuit
4. 58 – SDM
(U1064H) U1000 and U1255 Class 2 Communication Malfunction
5. 60 - IPC (Instrument Panel Cluster)
(U1040H) U1000 and U1255 Class 2 Communication Malfunction
(U1080H) U1000 and U1255 Class 2 Communication Malfunction
(U1176H) U1000 and U1255 Class 2 Communication Malfunction
(U1160H) U1000 and U1255 Class 2 Communication Malfunction
(U1088H) Class 2 Communication Malfunction
7. 80 – Radio
8. 99 - HVAC (Heater Vent-Air Conditioning)
(U1060H C) U1000 and U1255 Class 2 Communication Malfunction
9. A0 - LDCM (Left Door Control Module)
NO Communications
10. A1 - RDCM (Right Door Control Module)
(B2283) B2282-B2285 Battery Supply Voltage Circuit
(B2285) B2282-B2285 Battery Supply Voltage Circuit
11. AC - SCM (Seat Control Module)
(B0851) Battery 1 Out of Range
(U1060H) U1000 and U1255 Class 2 Communication Malfunction
(U1300H) Class 2 Short to Ground
12. B0 - RFA (Remote Function Actuation)
(C2100H)
(C2105H)
(C2110H)
(C2115H)
13. A6 – SCM
I am not sure at this point if there is a fix, other than detonating the car in place, but any assistance would be greatly appreciated.
Here are the codes:
4. 58 – SDM
7. 80 – Radio
NO Communications
(C2100H)
(C2105H)
(C2110H)
(C2115H)
13. A6 – SCM
