UncleBuck
I thought I would post this as a different thread, it doesn't seem to be a security code issue. Just when you thought you were safe! Security light came on again on the way home from the golf course. Had the P1631 code again, reset that and car seemed okay. Went out that evening, car would not start. No codes, seemed like low battery. Charged it over night, but it is 4 years old. I reviewed the CL video were Paul talked about the importance of batteries. Decided I probably need a new battery. Got the ACDelco 86PS as recommended by the thread. However, it is rated at 590 CCA and 110 RC. Not the specs recommended by the thread. What's up with that? Is this still the battery I should use or should I get something else????? New battery is currently on the charger awaiting a good response.
