ZRGator
Gone but not forgotten
- Joined
- Aug 26, 2004
- Messages
- 322
- Location
- West Friendship, MD
- Corvette
- 1993 40th ZR1, 1967 Red 427/400 coupe
So my Optima battery fried sometime back and what with purchasing a new office and moving into it and getting set up and so on...I have just gotten around to replacing the battery. I bought a new Delco 24-6 (per recommendation of JohnZ) and I was installing it tonight.
BTW, taking those little bolts off the access panel is a nuisance...any how, after I got the old Optima all unhooked and slid it out through the access, I found a good bit of white powder residue all over the bottom of the battery tray. Yep, battery acid, I know. So I want to take out the battery tray and recoat it and, from what I see, there are four bolts holding it to the frame...is this correct? I also need to remove a small triangular panel under the tray (it's kinda inside the frame) and I see two remaining bolts to do this, right? No hidden extras anywhere you guys might warn me about?
Also, battery tray coating...where is it available so I can get it quick?
Thanks for the support, guys.
