I was messing with my sound system and had an arc occur...wasn't sure what all happened, but the system was working fine. So i went to start the Vette and no power went to the Crank. All fuses are fine. I then tried pumping the clutch and poof, the car started...and the Headlights came on automatically. I have tried three times and had the exact same results. From looking on forums, it looks like a common BCM problem. I can order the part, but how do I reprogram it? The service manual says use a scan tool...will it connect to the BCM, or do I install the BCM and then connect the tool under the drivers seat and go from there?
thanks...
thanks...
