macx
I guess I should have just said best port flow, not size.
Any idea for the optimum intake port flow for a mild cam
(206 @ 050 & .435 lift) to support about 320 hp
at 4500/5000 rpm on a 9-1 cr 350 inch engine?
I'm trying to figure which of 2 heads will not leave any
power on the table at 4500/5000 rpm, but without getting
too big of a port - capable of too much airflow - so the flow
slows down at lower rpm so it won't fill the cylinder properly.
Torque & throttle response at 1600 to 1800 rpm will be very important
for this car's gearing on the highway. That'll be freeway speed.
I've looked and can't find any calculators or formulas for that -
of course there are quite a number of variables.
I'm looking at a couple options that are good quality heads
and within my budget -
One head flows about 210 and the other flows about 185 at .435 lift.
They both have 170cc intake runners and are Vortec style heads.
The bigger head flows about 235 at .500 so isn't really that big of
a head - a typical 1.9 valve Performer flows about 215 @ .500.
The engine will be real mild, though, and never see the high side of
5500, if not 5200 or so. Peak hp will be at 4500 and peak torque
at 3000 per the Cam Quest dyno program in Comp Cams website.
Building for good mileage for long trips, with 3.31 gears, 200-4R and
27" tires on an 81, so need good low rpm torque. BTW it's Pro Jection
efi on a Performer intake, not carb'd.
Would 185 restrict it at 4500/5000, or would 210 be too much
for 1600-1800? Which would be better and why - if you have
any more of an idea than I do. Or maybe that's so little difference
it doesn't really matter?
Appreciate any thoughtful, informed SWAG estimates!
Of course with suporting info / theory / what have you.
Even some actual experience, maybe even on a similar engine,
would be just super.
Thanks!
Thanks!
