On the PCM tune,who do you recommend?
\db2
I agree...I wish I would have done more research myself. I would have saved approx $700. I DO like the borla and the sound of it AND I will tell you it is definately lighter then the stock system so you save on weight...but still. I may have gone the other way.A 96 LT4 stock cat back is not too bad for a stock exhaust just replace the resonator with a X pipe and Magnaflow mufflers,or several others make 2 3/4 inch inlet mufflers to replace the stock ones. I wish I had know this before I installed a 2 1/2 inch Borla cat back on mine.
\db2
Take it to Jeff Creech at Carolina Auto Masters in Durham, NC for a dyno tune. He tuned mine and it runs like a scalded dog.![]()
Also, an electric water pump is a great mod on LT4's. My et dropped 2 tenths in the 1/4 after adding one. 4.10's are probably the best single mod on a LT4.
www.pcmforless.com will get you close. But the best way is to have your Vette custom tuned and remapped on a Dyno. If your LT4 is stock, start with a open frame and K&N air filter. A 96 LT4 stock cat back is not too bad for a stock exhaust just replace the resonator with a X pipe and Magnaflow mufflers,or several others make 2 3/4 inch inlet mufflers to replace the stock ones. Now you have a 2 3/4 inch cat back that will out flow a after market 2 1/2 cat back for much less money. I wish I had know this before I installed a 2 1/2 inch Borla cat back on mine. But I still have my stock 2 3/4 exhaust for when I go 383 with the engine.
I can't stress enough ... get a tune.
When I went from stock, to my LT headers/exhaust I lost 10 HP on the dyno. I was waaaayyyyy rich ... 11.5 A/F ratio. Plus without tuning out the rear O2's with most LT installs, the check engine light will always be on.
I've worked on mine some and got the fuel trims much closer. Haven't been back to the dyno but the butt-O-meter says its better now. Still have a little Optispark break-up at higher RPM's, gonna deal with that and the cam swap.
Gears
Any car will be more responsive to a gear change than any other mod.![]()
Louis.....just curious, why didn't you go to 383 when you had to rebuild?
Most LT1 are in need of a tune after any major mod's. I replaced the fuel pressure regulator(adjustable) on my LT1 TA and when I Lowered the PSI 5 PSI from the stock setting it ran better. I read on T.P.I.S. catalog that most LT1 are a little rich stock.
A gear change does Help as long as you can get traction. My 96 LT4 is a OBDII and every time I do anything major to it I have to have it remapped. Or the check engine light comes on :-(
Ditto, but the 2 1/2 inch Borla Sounds sooo Good. And like you said our LT4 will not out flow the Borla cat back. But if we ever go 383 or something else (Super Charger) it's good by Borla. If I had the extra money with a 383 or 396 a B&B 3 inch might be the better way to go. And a set of Long Tube Headers. I am still going buy a X pipe from Racer70XX www.advancedautocc.com. for my stock 2 3/4 LT4 cat back. And see how it sounds with no resonator(X pipe) and stock mufflers.
