best shocks + exhaust replacement?
  • Thread starter Thread starter boonie
B
boonie
My 1994 C4 6sp needs both it,s shocks + exhaust system relaced i have the Z07 suspension and iam interested in installing a cat back exhaust system, is Flow masters the best way to go? and for shock replacement i was looking at either KYB or KONI, i would appericate any opinions. thanks boonie
Bilstein shocks
Whatever exhaust you pick should be solely on sound preference. They all give the same ~10hp increase.
Corsa is popular for LT1s.
Gotta agree with Vader - I did a lot of research on shocks and ended up with the Bilstein shocks - couldn't be happier with the result in the ride / handling improvement....as far as the exhaust - I did the Corsa system and it certainly improved the "voice" of the car. The real beauty of the system is the lack of resonance and the way you can very the exhaust note with the throttle. One of the best aftermarket improvements I've made. :w
I installed a Power Effects exhaust system, it sounds great, thy're adjustable and you can tune the sound in from wide open to just about stock.
Can't comment on the shocks, as mine are originals, but I did changed the factory exhaust. I chose a chambered exhaust system and could not be happier. :)
