Bestdavidd
- Joined
- Mar 14, 2011
- Messages
- 69
- Location
- South America
- Corvette
- 1992 Chevrolet Corvette LT1 Engine manual trans
Hello Everybody!!!!!
I have a question! And my question and my story is that:
I own a 1992 Chevrolet Corvette, manual transmission, with a problem. The car starts when he wants! I bought the car in that condition, but when i bought the car, if the car does not start, you open the hood and touch the computer of the car once or twice and the car starts fine. Thats happened when you try to turn on the car like 2 or 3 minutes later before turn off the car, if you turn on the car like 10 or 15 or more time before you turn off, the car always starts!
I removed the old stereo of the car, was a DVD player with a screen of dvd, i removed that because doesnt work. When i removed that simply the car doesnt start, even if you touch the computer or do wathever you want, NEVER starts! The cars has more than 1 week and dont start, and myself every day try to start the car and no results.
Reading and reading in internet, i have tried today ``vats bypass´´, the ohms of my key was 6040, im in 12. I went to an electronic store, and i didint find a resistor with that ohms, so i buyed 2 that gives me 5.800ohms, thats the low in my 12 scale:
Number 12
Nominal: 6040
Low 5798
High 6302
After reading that i thought that i need something between 5798 and 6302, so i thought that 5.800 will be good.
Ok, i arrive to my home and inmediately i install the resistors, i soldered the 2 resistors and i test with my multimeter and perfect! 5.800 ohms, so i soldered that to the 2 cables of the VATS cable behind the dash, and nothing happened, i test the other cable that comes to the key and perfect! 6.040 ohms! So, the car read the key!
The problem, i use my multimeter with the cable that goes to the VATS, and tells me -7.04 (that value does not will be in 0? like when he read the vats goes in 6040 ohms?), i conect the cable with the other cable to the key and tells me -6.76 and i have soldered the 5800 resistor to that with the cable connected and tells me -6.50, so i thought that i need a 297000 ohms resistor to arrive to 6.46 ohms to the vats. I thought that because if you add 11.800ohms (thats the key with 6040 ohms and the 5.800 ohms resistor) and reduces the ohms to the vats in 0.54. And you multiply 0.54x25 and you have 297000ohms, the quantity that you need to convert -7.04 to 6.46ohm.
i soldered 2 resistors of 150k each one and nothing happened, when i connect only 1, the value was on -2200ohms, so i dont understand NOTHING, i thought that with the 2 the number will be 6000ohms, but not! So im going crazy...
So, i think my VATS is ****ed.... and fo that reason tells me a negative value and dont read the key and dont start the car! im not a Engineer in electronics of nothing at all, im just a man thinking to fix my car!
So i wanted to know if somebody can help me to fix my car!
Everything i know is from that forum:
http://www.corvetteactioncenter.com/forums/c4-technical-performance/88349-vats-bypass-tutorial-pics.html
The cables, all is exact to my car, because is the same car, just 3 years older! But nothing changed!
Please im waiting for an answer because i need to fix my car soon!
Thanks a lot Everybody!
if need more information, tell me and i give wathever you want!
Number 12
Nominal: 6040
Low 5798
High 6302
