Block Stamping ID
bshaw1
New member
dresher, pa
I have a 1957 block 3731548 with the stamping T62IG -
What does the "IG" suffix stand for?
Thanks,
Bruce shaw
It's not "IG" - it's just "G". '57-'59 block stampings only used one digit for January through September ("1" through "9", vs. "01" through "09" used from '60 on). The "T621G" says it's a '57 283/185hp 2-barrel Turboglide passenger car engine built June 21, 1957 at Tonawanda.
As a side note, this is the only V-8 engine combination Chevy ever built that has a crankshaft specific to the transmission it would get later; Turboglide crankshafts had a HUGE hole machined in the flywheel flange to accommodate the HUGE pilot on the Turboglide converter, and can't be used with a manual transmission (nobody makes a pilot bushing that large).
Just noticed this is your first post - welcome to the CAC! I see your ads every month in the NCRS "Driveline" magazine. :)
I'd also like to welcome you to the CAC.
Tom
Thanks,
Bruce shaw
It should also be noted that you have a Tonawanda block.
In 57 all blocks were Flint/Saginaw cast blocks.
Tonawanda blocks have many embossed and debossed "T's" on them.
They're also missing the oil galley pipe plug on the front of the block.
What I'm saying is that you cannot make this look "Correct" for a 57 Corvette. You need a Flint/Saginaw casting.
Chuck
