blower resistor
what year is your corvette????
If the problem is your blower isn't operating on all speeds, remove the ac relay on the firewall, open it up, and pull a piece of sandpaper through the contact points.
Worked for me on two of my vettes.
It may be mounted like this, sideways, or around the corner(chrome in my pic).
Hi, not sure if you got this sorted yet. It is worth checking the relay as It bypasses the resistors, so a problem in the relay could cause it to work on hi speed only. If the resistors are ok, you sould have power on the dark blue wire at the relay.
