Hot Rod Roy
A good mechanic?
A good mechanic would be able to quickly find the cause of the problem. A good mechanic wouldn't even think about replacing the engine until he had determined what the problem is. Only 80,000 on an '84? This car is just barely broken in!
You're going to be very frustrated if you replace the engine, and then discover it's something simple, or if it's something not even related to the engine!
