IH2LOSE
- Joined
- May 24, 2001
- Messages
- 3,908
- Location
- We Will All Meet Again
- Corvette
- 1966,and a 1962 thats almost complete
Barry I never turn down advice that I can learn from.You really enlightened me on this.I was afraid if I go lower into the floor area I cant aim it correctly with out it getting lost under the dash.I normally have this work done by an high end stereo shop once the cars are complete but I have to make up my door panels and was going to do this myself. I may have to have hime come to the house to aim and place the speakers. Allthough its a convertable with a small cabin I do exspect concert quaility sounds from it.
BarryK said:Larry
I may not know much (if anything at all) about working on cars, but i DO know a fair bit about car audio systems. I've even designed and helped install systems worth $75,000 or more and that were winning systems in national car audio competitions. It's been a number of years now since I was in that industry and many things have changed but the basics of acoustics do not.
If I may make a suggestion or two regarding the stereo system I hope you won't be offended by the unsolicited advice.
Regarding the front speaker placement, your optimum placement would actually be the kick panel area with the speakers aimed up and towrds the opposite side of the car directed to the other person. This means the drivers side kick panel speaker would aim toward the passenger at ear level and the passenger side kick panel speaker would aim toward the driver at ear level.
The main reason for this is too try to equalize (as much as possible) the wavelength between the left and right speakers. If the speakers are in the doors, the speaker on the left side is only a few inches or maybe 12-18" from your ear but the right side speaker could be 3-4' away from you. this causes the entire "soundstage" to appear to be coming from the side of the car you are sitting on. By moving the speakers down to the kick panel area, there will still be a difference in distance between the left and right side speakers to you but the difference is reduced and therefore your soundstage and imaging is greatly improved.
If you feel that for whatever reason you can't go with the speakers in the kick panel and MUST go with them in your doors, than at least try to put them as low and as forward in the doors as possible and again cross-fire them to the opposite side aiming at the ears of the occupent in the other seat (direct the drivers side speaker to the passenger at ear level and vice versa). try to avoid aiming the speakers straight across and firing directly at each other as this will cause a loust soundstage, imaging, and even worst, phase cancelation.
If at all possible, wherever you mount the speakers, see if you can construct an enclosure of the speaker (fiberglass would be perfect) for much better sound quality and if it IS in the doors than sound dampening material such as dynamat is great to reduce resounce and vibrations that will detract from your sound quality.
If you have any questions regarding your system or anything I can do to help you in this area i'll be glad to. Maybe I can finally help someone else out on this forum for a change!
