wrc3
Ok so I am about half way done with the body mount install on my 76 and I figured I would write up something real quick just to let folks know how it goes so far.
First I would say unless you are willing to pull the entire body off the frame you probably shouldn't start this project. The reason why is this. On a 76 you have 8 mounts 4 on each side numbered 1-4 from the front of the vehicle to the back. Numbers 1 and 4 on each side are bolts that can be snapped off or cut out and you can still do the work, but if for some reason you snap off the bolts for 2 and 3 on either side you are utterly screwed. Both 2 and 3 on each side screw into brackets welded on to the frame that hold square nuts in them. If for some reason those bolts snap in there, and they very easily could, then you will need someone to cut the old brackets off the frame and replace with new ones and I am just not sure how that would be done with the body still on the frame.
So if you are still willing to take the chance and do this, it goes something like this.
First finding all the bolts...
Number 1 is located behind the front wheel and the top of the bolt can be seen and reached from inside the engine compartment. The bottom obviously can be seen from laying under the vehicle and looking just inside where the intake vent is. To remove this bolt you will probably need two guys, one holding the bolt from the top the other working the nut from underneath. For this bolt you need an 11/16 deep socket and an extension to get on the nut and the excess bolt. In my case one of them snapped off and the other had to be cut out.
Number 2 is located behind the kick planel on the inside of the vehicle and only the top portion of this can be seen as the bottom is screwed directly into a bracket on the frame.
Number 3 is found by removing an access panel with 4 screws that is in the front of the rear wheel well and same as #2 only the top can be seen.
Number 4 finally can be seen by removing the rear compartment carpeting and going to the far rear corner inside of the vehicle. From underneath the vehicle you can see the bottom of this bolt which is behind the rear tire sitting on a bracket welded to the frame.
Next Preparation....
Douse all the bolts in PB or some other type of penetrant and let them sit. Do this a couple of times. Then go to each bolt and loosen them (see if you can at least). I personally was lucky and got all number 2 and 3 bolts loose, but snapped off #1 and had to cut the other #1 out and both number 4's snapped right off.
Take off the rocker panel (or whatever it is called that runs along the bottom of the car between the wheels. If you have sidepipes (which I do) you have to take those off too.
Actually doing the work...
Now jack up oneside of the car on jack stands just enough to get the rear tire on that side off. Take the rear tire off to have access to the #3 and #4 bolts. You can go ahead and remove these bolts entirely now. The #4 bolt bracket is probaby shot so you will need to fab a new one or buy one. I bought mine from Paragon at 37.00. I thought it was a bit steep for what you get, but I am not sure how much a fab job would cost. You can now also completely unbolt #1 and 2 bolts as well.
Now that all bolts on one side of the vehicle are off and the bolts on the other side are loose you can jack up the body enough to get the old bushings out and the new ones in. To do this I ran a peice of 2x4 across where the rocker panel was on the metal strip that is there and put a jack in the middle of the 2x4 (you may even want to use 2 jacks to spread the stress out on the body if you have 2 available, but one will work). Now jack the body up. When doing this you should be sure that only the body is moving and not the entire vehicle. Those old bushings wedge in there pretty tight sometimes and may actually start to move the frame with the body. Particularly at #4 i had to wedge a crow bar between the bracket on the frame and the bracket on the body to get the rusted and squished bushing to come out.
The body should move fairly easy up about 2-3 inches off the frame you now have enough room to pull the old bushings and put the new ones in. In doing this I fit one new bushing at a time each time lowering the body to basically press the new bushing into place.
Once I got the old bolts off and the old bushings out, putting the new ones in wasn't that big a deal. Everthing went pretty fast from there. Run the new bolts and keep them loose.
Now you are basically done and just need to repeat the process on the other side. Finally once you are done you should tighten all bolts (i have yet to get to this so I am not sure what the torque spec is, if there is one) and you should be done.
My Personal Hangups...
The things that took me the longest to do were the following:
#1 on the drivers side stripped so I had to cut it out. There is little room to get a dremel on it so it took forever to get through the bolt
#4 brackets on both sides were shot. To get these out you need to go to the inside of the car and cut off the tops of the rivets that hold them in place...ya that was a pain. You then need to remove the old bracket or the chunks of rust that were the brackets and then replace with a new one and either re-rivet or bolt. I am probably just going to get some rivets, but I have seen other posts where people use bolts instead.
Well that is about it. So if you are willing and feel that you need to, you can probably do body mounts over a weekend or so. Just realize that when starting this project you may end up having to take the body all the way off if the wrong bolts snap...
