- Thread starter
- #21
John Mcgraw
- Joined
- Feb 18, 2003
- Messages
- 816
- Location
- Austin Tx
- Corvette
- 1960 Roman red, 1959 resto-rod, 1965 resto-rod
Larry,
The decision to make the body fit so close was in part for shop room, but strength of the cantilevered arm was a consideration. It has enough room for sanding and body work, but does not allow a straight shot with a spray gun in these 2 areas. I made the pivot pipe too long as well, and I could take at least 8" of total length out of the entire unit by trimming the pivots down. Too bad you are so far away, I took my body off the rotissere for the last time this past weekend, and you could use it. Unfortunately, It would probably cost as much to ship it to you as it cost to build! I finished up the last few little items on my chassis Saturday, and installed the body for the last time, I hope! I will now take the rotissere apart and store it at work in one of my storage rooms, so that it is out of the way. Here are some pics of the body going on for the final time. It is a real milepost on the project, and I can see a light at the end of the tunnell!
http://www.villagephotos.com/pubbrowse.asp?folder_id=1072981
Regards, John McGraw
