Bosch ABS 14084083 available - Bosch 0 332 512 006
chris123
Wilkes Barre, PA
Hi all: I have 1 Bosch ABS relay available, part #: 14084083; Bosch part #: 0 332 512 006. I believe it was designed for the earlier 1986 style ABS systems, however it will fit and function on the '87 - '89 systems as well; see below for pics; this is very similar to the 1636973 ABS relays that I have for sale in one of my other posts/ads, however this relay is slightly different in that it doesn't have the plastic flange or locking tab on the bottom as pictured. Also, the metal clip is on the bottom instead of the top of the relay and is mounted in the reverse direction than the other relay. The functionality of it is the same however. Price is the same as the other relays, $40 plus $2.25 for domestic first class shipping.
I will buy your brake relay part number 14084083 ralph ph.843 247 0144 thanks
I will buy you brake relay part number 14084083 phone 843 247 0144.Ralph
