V
vettatude
Ok, so I'm thinking of replacing just the HU of my Bose system. I have seen several different adapters and level adjusters to do this hookup easily. Are these adjusters like the PAC OEM-1 necessary to do this? Can I just get a harness that plugs into the factory harness? Is wiring the high level outputs of the aftermarket HU straight to the factory harness too much signal? I have a 2000 Mustang GT with the Mach system and just made some RCA to speaker wire adapters to retain the factory amps and it worked great. I only had to put a reisistor in the amp turn on line to drop the voltage to 7 from 12, got rid of a popping noise. Does the corvette HU turn on the Bose amps? How much voltage does it take to turn on the amps? Whew, I guess that's about all. Thanks for any insight you might have.
