gmjunkie
Advance,Auto Zone,Napa ot'ta have one,I think I bought mine at Northern Tool!~!!Thanks Hib for the stethoscope suggestion, I popped into Loews this afternoon to see if they sold any, nope. But I do have the tubing now.![]()
Advance,Auto Zone,Napa ot'ta have one,I think I bought mine at Northern Tool!~!!![]()
, thanks!:duh I thought I was dropping it off to a good shop, it's one of the highest rated Corvette Only shops in the DC area, but maybe I got a short timer for a mechanic that day. :cry
I think you are right on this one. never knew the "vibration dampening" flywheel was in Corvettes.I don't think it's the surface either,I think the fly wheel has some broken springs in it!~!!I was pointing out the Butcher Resurface job,It's plainly been ground unevenly by hand!(blow the 1st 2 potos up 150% and take a good look!)At best it has to be somewhat out of balance now!! That will amplify any other noises from broken springs or worn bushings in the duel mass that not necessarily were audible before!~!! I've been on a couple Duel Mass rodeos before,even changed out a cam and lifters over a noise very similar!~!!
I may be WRONG,
I have been before!! :L
Thats why I always advise folks to join the local Corvette club and hear it from customers and what they have to say. What a chicken s*** service writer says is only one lie short of being a politician.
Live and learn...![]()
Had ya gone to a good trans shop they would have replaced the flywheel.....![]()
Push in the clutch pedal and see if it changes . Put it in gear and slowly release the pedal and see what the sound does.
You said you surfaced the flywheel. If it is OEM it has the dual mass flywheel. You may have a flywheel about to come apart. ZF doc told me the early flywheels had no cover over the seal in the flywheel crap can get in and take out the seal.Then things start to go wrong.
If it appears to be flywheel related you might want to contact him, he is very good about sharing information.
Scav.
BTW Before I replaced my clutch and flywheel I had a similar rhythm but more of a click when it was warmed up. That is gone. Did you notice a click before the knock started ?
I located this after I posted.
ZF dual mass flywheel
ad
