pbcanney
ran into a bit of a conundrum today.
In reinstalling the brake booster into my 81 , which was an automatic when I took it out, and now has pedals from a 79....
The clevis was about an inch and a half away from the pedal where the pin slides into the brake pedal.
I reinstalled it, as is, but the brake pedal was about 2 inches closer to the floor (than the clutch pedal). Not knowing if this is "normal" I continued hooking up the wiring under the dash, and when I install the the brake light switch, that is activated when pressing on the brake, I cant get it to make a contact with the switch (even all the way pushed into the bracket)
So I removed it, thinking unscrewing the rod in hopes it was adjustable, but it just spins
So here are my questions...
Should the rod be adjustable?
Is there a different booster for manual transmissions?
Is there a different push rod that the cleavis mounts on for manuals.
anyone have a booster with rod and cleavis of known good quality out that can measure from the flat of the booster where the 4 bolts mount to the hole of the cleavis.?
this really knocked the wind out of my sails today. especially having to pull the booster out after fighting with those 4 mounting bolts for an hour installing it.
;help
;help
