socor7
What should I use to clean the calipers both internally and externally. Internally I mean the pistons and the chamber they flat in.
Brake cleaner?
Carb Cleaner
WD 40.
they are pretty greasy form a leaking caliper.
where is the best place to get new rings and boots (local parts place)or do I have to order from corvette mag.
I know there are two different types of rings, how do I tell the difference, I can post a pick if you like so you can tell me.
Drew
Brake cleaner?
Carb Cleaner
WD 40.
Drew
