Brake Caliper Rebuild
socor7
Denver, Co
1976 White with red Int 4 speed
What should I use to clean the calipers both internally and externally. Internally I mean the pistons and the chamber they flat in.
Brake cleaner?
Carb Cleaner
WD 40.
they are pretty greasy form a leaking caliper.
where is the best place to get new rings and boots (local parts place)or do I have to order from corvette mag.
I know there are two different types of rings, how do I tell the difference, I can post a pick if you like so you can tell me.
Drew
Brake cleaner...not WD40.....it leaves a residue....use brake cleaner...watch out for painted parts as brake cleaner loves eating paint....
Brake cleaner?
Carb Cleaner
WD 40.
Drew
I've just repaired my front calipers on my 74 last night and I bought the caliper kits from NAPA auto part.
I don't know if there a NAPA auto part in your area and if they use the same part numbers over there. but just in case.
the part numbers for mine was:
Front caliper kit napa product # 452. priced at $33 each canadian funds
Rear caliper kit napa product # 453. priced at $40 each canadian funds
the kit includes all you need to restore you calipers including O rings and boots. and YES. use break cleaner.
Good luck
Dan
