H
hotwheels1981
I have this ongoing problem with bad calipers. I get from 50 miles to 500 miles if I'm lucky. Has anyone had problems with calipers and if so how did you fix the problem. I have put at least 4 sets on the front and 2 on the back. Any suggestions..since the front is gone again and I need to FIX the problem again. They leak and then the brake pedal goes to the floor. When that happens at least 1 caliper is shot. When they are changed(both sides) the caliper is so very badly pitted. Any information would be greatly appreciated.
Thank You
hotwheels1981
Thank You
hotwheels1981
