I am considering changing the brake fluid on my 71 to silicone (DOT 5)fluid. I know the benefits of this this change but would like to hear from others who have experience with silicone regarding the pro's and con's of such a change. Thanks.
It's been my understanding that standard brake fluid being hygroscopic was the cause of the original problem because the retained moisture caused the bores to rust and pit and therefore leak.A hygroscopic brake fluid would have most likely contained the moisture, and held corrosion to a minimum.
A plus to silicone besides not attracting moisture and having a higher boiling point is that it won't ruin your paint.
Hey Bob, thanks for the post and the pic! That sums up my description to the 'T'! I had a lot more corrosion in the bores to the point that the bore bottom wasn't definable.I had silicone brake fluid in my 72 for 25 years (up on blocks). Most of the fluid seeped out of the calipers so before I put the car back on the road, I wanted to change to o-ring seals and stainless lines. Fluid in the master cylinder was clear with a slight purple tint. Fluid in the calipers was also clear but with the rust Rod75 described in his post. A system with silicone (DOT-5) fluid doesn't change color when water finds its way into the system and from my experience it doesn't deteriorate over time. If something is going on inside the brake system, there's no hint, even if you bleed the calipers. The only way to verify that your DOT-5 system is water-free is to disassemble it. Once you clean out the calipers, you get to hone your brake bleeding skills because as Hib pointed out, you are going to spend more time and fluid to get all the air out. If you have another Vette or daily driver with ABS, make sure you use DOT-3 or -4 because silicone will really mess up the ABS. If you have a pressure bleeder, make sure you thoroughly clean it before switching fluids.
I think this is what Rob75 was describing when he disassembled his calipers: "The back of each piston bore was loaded with bright orange rust goo and particles! The piston backs were the same."
Thanks Rod,Hey Bob, thanks for the post and the pic! That sums up my description to the 'T'! I had a lot more corrosion in the bores to the point that the bore bottom wasn't definable.
This just reinforces the benefits of DOT3 & 4 brake fluid.
By the way Bob, I've been following your threads and I think you do amazing work!![]()
