I
IndyPaceCar78
For those of you that read the post that Buckskin had originally posted about tail lights not working etc...
I had an inoperable right brake light. After multiple attempts to diagnose the problem, its resolved!
First off I checked the bulb, correct size, socket, connections, fuses.... the right turn signal would still work, and being a dual filament bulb, the brake light would not even after I replaced the bulb anyway.
Come to find out, the problem was actually the turn signal switch in the steering column. The part was $47 and corrected the horn not blowing too!
Just thought I'd post this out in case anyone else had, or did run into the same issue. Not sure if this is a "typical" prob for '78 or any other yr for that matter......
You guys have been great, and thanks for all your advice!
Brian
Brian
ad
