R
railer75
I need help with a brake problem on my 87 Vette- This is my first Corvette so I am not very familiar with it. The front brakes hang up and won't release completely- which causes the wheels and rotors to get very hot and excessive pad wear. The rear brakes operate normally. I have replaced pads,rotors, master cyl,brake lines-the system has been drained and flushed with new DOT 3. I can free up the brakes by releasing hydraulic pressure by cracking the bleeder valve,or the line at master cyl or at the abs unit. At this point I am thinking the problem is the abs-maybe a stuck solenoid? I bought a used replacement from another 87 on Ebay but when I was going to install it I foud the wiring was different! Mine has 3 harnesses/plugs but the replacement has 2. They both have the same model # -Bosch 0 265 200 020. I called the local Chevy dealer - they confirmed that there were 2 different set ups for that year, but had no other info. I could really use some advice- Thanks
