does anybody know how to put the brake fluid reservoir back on to the master cylinder? There are the rubber grommets that make it very very hard. Any tricks?
ya thanks alot....that worked. Every book i had said to put the grommets on the master cylinder first then push.
I tried putting the grommets on the reservoir first but i didnt want to push as hard as i ended up doing.
