L
loverboy
I have had break squeal since i purchased my car. Since then i have replaced the OEM rotors to new ones (4). I changed the pads (4) and still had noise. After that i got anoyed and purchased bear cross drilled and sloted rotors front and back and left the OEM pads on. The squeal still was there. The noise was less then before and sounded like it was coming from the back. So then I installed ceramic pads all the way around and the noise was gone. BUT 2000km later the noise is back now not as bad but it fads in when slowing down and goes away when close to a complete stop. The squeal in not a high pitch noise like it was before but still loud enough to here and **** me off. It still sounds like the back.
Just wanted to know if it could be a caliper problem or do i just have no luck. If anyone has any ideas on how to get rid of this problem I would PLEASE like some advice.
