L
LIBERTY
It's time to change brakes on my 86 coupe. Any opinions/ resources out there on good brake pads and slotted/ cross drilled rotors. My friend has '87 convertible. Should be same when considering pads/ rotors.
We ordered them from Sport Brakes in Dallas (www.sportbrakes.com). Their web site isn't updated so just call them at 972-620-9311 and ask for Ras or email at info@sportbrakes.com. We're more than happy with them and their service!!
4U2NV1986 said:I just did my 86. I went with power something cross drilled rotors from Summit Racing at around $80.00 ish, and they are nice. They have a gold cad plating on them for rust prevention at the hub. As far as the pads, I used the upper grade Raybestos pads and they are working out fine. If your doing the brakes, now is the time to swap out the shocks. Takes all about ten minutes per wheel to get the shocks off. I used KYB from summit at around $29 each.
Good luck
