B/STOCK
- Joined
- Oct 24, 2001
- Messages
- 195
- Location
- RI USA
- Corvette
- 2000 Magnetic Red Vert & 2015 DSOM Coupe Z51-3LT
I have a 2000 with 26,000 very easy miles on it. Last year I put on the chrome wheel drum covers and a new wheel and tire package from Tire Rack. The tires and wheels are perfect and role true to 150MPH the top speed I tested the package on. I put the wheels and tires on and torqued them (with a quality wrench) properly at 100ft lbs. The only thing I did not do myself is loosen the rear rotor to slip the covers under. I told the mechanic (a Corvette guy) to torque the main rotor bolt to 175 ft. lbs. which it calls for. After about a 1000 miles I am getting a slight pulsing when I brake. I am extremely easy on brakes so I know a @25K they rotors and pads should be fine. I did the same thing on my C6 about two years ago and it has been fine for 4k miles. The only difference is the rear rotor on the C6 did not have to be loosened. Any other reasons for this pulsing? Thanks Mike
